kennykamut
- blue grass, Iowa, USA
Hi guys
Can you give me some feedback?
I installed some 277 volt rated LED lights on a system that measured 281 volts. After about a year, several of the lights failed and kept failing. Then after measuring the voltage over a period of two weeks, it showed spikes of over 300 volts on weekends. So who is at fault here? Should I not have assumed 277 volt rated would be fine? Should 277 rated handle this with some wiggle room? Should the power company be liable?
Thanks.
Thanks.
