kirkpatrick88
- Denver, Colorado
I have read many arguments about the NEC with regard to the installing the grounding rod and ensuring it has < 25 ohms of resistance, or you need a 2nd rod installed > 6' from the first.
I recently moved into a house that was built in 1999 and it has only 1 grounding rod installed near the panel with a #4 connected to the copper waterline.
Based on what I have read here, most single ground rods do not meet the 25 ohm requirement and do not get tested. Most people just drop a 2nd rod and call it a day.
My question is: If this was your house, would you bother installing a 2nd ground rod or not worry about it? I would get the resistance tested, but it seems silly to spend $$$ if the results are most likely that I will need a 2nd rod anyway to meet current code. Obviously the inspector did not think that a 2nd rod was important when he looked at the system in 1999.
Thoughts?
Thoughts?
