jmsbrush
- Central Florida
Good morning guys, when installing a 2x4 lay-in fixture. Does the NEC required you to have 2 or 4 corners strapped by tie wires?
Thank you guys for your help, do you guys feel like it should be a NEC requirement to use tye wire on lay-in's?
That makes sense to me as well.Here, it varies with the jurisdictions. It should be a building and fire code rule, not in the NEC, IMHO, like smoke detector requirements. I could never understand why some jurisdictions used to require them to be screwed to the grid. A fire marshal once told me that the purpose of tying them up independent of the ceiling was so that, during a fire, they can tear the ceiling down without having the lights fall on them. Makes sense to me!
While the fire idea seems good, I do not think that is it. Otherwise it would be required everywhere.
I was told it was a building code in seismic zones, so the support might help prevent the fixtures falling down in a quake.
This is a great point to clear up. All area's are in a "seismic zone" they are classified from zone "A","B","C","D","E", and "F". Zone "A" being the lower end of the scale and "F" the highest magnitude zone.
I recently watched a security camera recording during an earthquake and the 2x4 troffer came down and hit a person sitting below it, looked painful.
