To be electrocuted you have to come in contact between two different points of potential or current is not going to flow through you. The water may have been energized, but so would the shore around it, although depending on conditions there could be a relatively short distance between significant potential levels - that is a possible place for something to happen, or if there were a metal sign or fence post near the edge of water it could easily be at a different potential than the water but maybe reachable from the water - you would have to touch both at same time of course.
