kwired
Electron manager
- NE Nebraska
- EC
Don't be giving POCO's any ideas.It's easier to pay for electricity after you use it than it is to pay for heating oil before you use it.
Did they use the screw terminal as a splice point, or was the wire windowed?I responded to an emergency call when a bed caught fire because an unused receptacle overheated due to a heater in another bedroom.
Which is why the UK among other places had coin operated interior electric meters.Don't be giving POCO's any ideas.
I know of a few people that have their service disconnected nearly every month for non payment. They might like this idea in some ways. Sure is inconvenient when it runs out, but you maybe only need a couple dollars and some smart management of usage and can get by a day or two and can turn it back on at any time of day and not have to wait for someone else to turn it on at their convenience.
Depending on how you wire this circuit and how many branch circuits involvedCan a 6A 3-gang light switch support 6 Amps on all three gangs, or is it a total of 6 amps? Let's say one gang is connected to a 3 amp light circuit, another to a 2 amp light circuit, and a third to a 4 amp light circuit. Will it damage the switch?
Most these I've seen only have one common terminal so only going to be used on one branch circuit. At least when there is three switches on a single yoke. Two switches, particularly the ones that take a "duplex style cover plate" typically have two common terminals but have separable tab for separate circuits similar to how duplex receptacles are commonly designed.Depending on how you wire this circuit and how many branch circuits involved
If using one 20 ampere branch circuit and paralleling the line, you only have a maximum of 6 amperes pere paralleled line to each 3 switches. The switchs only runs 6 amperes each, while the total 1 branch sees 18 amperes and should not damage the switch
I assumed he was referring to a 3 way switch whereThat doesn't sound correct. I have seen 15 amp 3 switch units. Do you think they could handle 45 amps? I know it isn't realistic but....
I misunderstood, I thought he was referring to a 3-way switch.That doesn't sound correct. I have seen 15 amp 3 switch units. Do you think they could handle 45 amps? I know it isn't realistic but....
