LarryFine
- Henrico County, VA
- Electrical Contractor
Re: 3-hole outlet in apt. ungrounded?
So, does that mean that we have the option to use a GFCI breaker or GFCI receptacle in any case, or is there a condition in which a GFCI receptacle must be used?Originally posted by georgestolz:
If you installed a GFI breaker, it would be persuant to (c).Originally posted by LarryFine:
Would be non-compliant if such a circuit were protected by a GFCI breaker, as opposed to receptacle?
I wonder why (b) specifies a GFCI receptacle.
(c) defintely does not specify whether a GFCI receptacle or GFCI breaker must be used.
If you installed a GFCI receptacle, that specific receptacle outlet would be persuant to (b).
If you load side out to a grounding-type receptacle from a GFCI receptacle, the load side receptacles would be installed persuant to (c).
Doesn't matter what you do, as long as it's one of the methods in (a), (b), or (c).![]()
