spark master
- cyberspace
I was asked to review an installation on a 3 motor mixing tank installation. 1 circuit, #8's to a disconnect. Trough under the disconnect. In the trough is what concerns me. 3 VFD's mounted on a wall. 3 circuits come out of the trough, #10's for 2 small motors, & #8 for the big 10HP motor. Obviously the 2 small motors don't need #8's, and #8's won't even fit in the VFD terminals. So they used #10's from the trough to the drives, and also #10's from the VFD to the motor. It's about a 5' run of undersized wire.
Considering the VFD kicks out if the motor goes over current, do I need to fuse where the #8's go into #10's ?
Normally I'd see drives mounted in a big control panel, with circuitry, and starters, & contactors. But this one was done simple, with just 3 drives mounted on a wall, and a speed control.
