Not many AFCIs being used on three phase circuits.
Maybe not in Massachewsets.
First, how can you tell which pole tripped? (other than Sq D with the Visi-Trip(r) indicators.)
How about west of billsnuff?
Roger
If this is in patient care areas there's a problem, see 517.13 (A)&(B)
Roger
............First, how can you tell which pole tripped? (other than Sq D with the Visi-Trip(r) indicators.)............
I guess you could take off the tie handle temporarily, no?
They're usually in the tripped position. Sq D QOs only make it easier to see it with their orange visi-whatchmacallits. But every other brand breaker I've seen has a tripped position that you can see as well.
I'll have to find out how its classified... technically its the doctors offices...but patients are diagnosed & treatment is done, however, no overnight care. So I guess it very well could be a Patient Care Area.
Shoot. I put 3-ph MWBC is dwellings all the time!![]()
If patients are examined, it is a care area.
This may be a pretty good Add/Change order for the boss....
Or something he didn't take into consideration. :grin:
14/4 is much cheaper.
Nobody's asked me what a 3 phase branck circuit is yet, though :grin:
Thats the good and the bad about MWBC.If you've been trained how to make a good splice and can perform it well you will be fine. I have installed thousands of MWBC and never had a failure. It's when you have to work with other peoples MWBC's that can't make a proper splice. That's when I've ran into problems.
..........Of course, if the MWBC neutral was cad welded, this issue would never have arisen![]()
You really do live a sheltered life don't you? I can walk up to most any manufacturers panel and show you tripped breakers with out any red indicators. :roll:
Roger
Sure, for one alone. But the handle won't be in the midway position when tied to the other two.
