I need a little clarification on 3phase vs single phase.  If I have a 3 phase 277V service and am using it to run 16 fixtures that each indivually use 6.3 amps.  How many fixtures can be on a 10awg neutral wire if the load is distributed evenly across the 3 phases.  Right now I've got 3 10-5 cables for the 16 fixtures but not sure if that shouldn't be 4 cables instead.  I think I've been oversizing the wire in the past.  I know in 3 phase 480V that you take the number of fixtures x amps per fixture and divide by 1.73 to get total amps, but I'm not sure if that formula applies to all 3 phase calculations.  Any insight would be appreciated.
