dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
Where I work we are rerouting and dividing some cabling and I came across a 3 phase calculation that stumped me let me build it below
Low voltage switch gear 480V Delta ungrounded
Phase A B C
3 Transformers fed by
AB BC AC
Output to 3 fixed loads 600a 600a 600a
240volt 2 wire each
My question is given I know when the heating grids are fed with 240v I will get 600a current draw how much current will each phase see on the 480 delta ?
I wanted to simply amp clamp this but this could not be done due to company safety regulations plus I could not remember how to calculate this.
Thanks
Dave
Phase A B C
AB BC AC
240volt 2 wire each
Thanks
Dave
