Greetings Everyone.
Just trying to get some old stuff revised but cant seem to do it.need help.
When we have a single phase load say a bulb, there are two wires connected to that bulb.
1. Hot Wire 2. Neutral Wire.
the current flows from the hot wire and then returns back via neutral wire. this way current completes its path.
when we have a balanced 3Ph system( STAR or WYE), each phase draws the same amount of current and the neutral current provides the return path.
How is the return path provided incase of DELTA system?there are only 3 phases.so how is return path provided if we have a 3ph load for delta system.
Thanks
Thanks
