Ok so I know that to calculate the total power supplied by a balanced three phase wye source is to do one of two things. You can multiply the L-L voltages by the the line currents and then multiply by 1.73 to get the total power. Or you could add the individual powers across each wye brance and sum then together to get the total power. The power on each brance is calculated by multiplying the L-N voltage times the current on the branch.
An example of a 480V 100A system.
1) P = V(L-L)*A_line*1.73= 480*100*1.73 = 83.04kVA
2) P = V(L-N)*A_line*3 = (277)(100(3) = 83.1kVA
What about for a delta system? Can you simply take the power across each balanced delta element and sum them for the total power supplied by the system. I know you can find the total power by multiplying the L-L voltage by the line current and then multiplying by 1.73, but can you add each of the three power elements as well to arrive at the total power? My calculations below show that it looks like you can do it this way but I just wanted to verify?
1) P = V(L-L) * A_line*1.73 = 480 * 100 * 1.73 = 83.04kVA
2) A_load = A_line / 1.73 = 100 / 1.73 = 57.8A
P = V(L-L) * A_load * 3 = 480 * 57.8 * 3 = 83.23kVA
