bobbymari
- los angeles ca
we have a 120/240v 3 phase set up meter/main/distribution panel for apartment elevator which will also feed a sub for house lighting/laundry room.
Question , is it permissible to feed the single phase sub using 2 poles of a 3 pole breaker?
No single 120v loads just a 240v sub feed using 2 poles of the 3 pole breaker.
Reason being is our 3 phase plans have us using the exception to 408.3 using c phase as the wild leg at the distribution point
Didnt want to cause confusion by installing a 3 phase panel in laundry room and switch the wild leg to b phase since it would not fall under the exception as being in the same switch board or panel board
prefer to leave laundry/lighting sub as is , single phase sub
