fyi... there was a thread back in 2021 about this question. And in post #35 of that thread, I used a typical delta to wye step down xfmr to create the 3rd leg from a 208Y/120 service which had only L1, L2 and N.
Wow! This is interestin My motors like higher voltages because they are from Europe. 230V is fine. I oversized the transformer already. Should I go this way? It's up to you. I'd be interested in hearing what others have to say about it.
forums.mikeholt.com
For those curious, the "trick" in the experiment discussed was you use only the Wye side, nothing was connected to the delta windings. L1/N and L2/N energize their 2 Wye windings, which in turn energize their respective windings on the Delta side. Since all 3 windings on the Delta side are in series, the 3rd Delta winding is also energized and it, in turn, magnetically excites the 3rd (L3/N) winding back over on the Wye side.
To summarize that long thread, the experiment worked, but I would not connect customer equipment to it. The third Wye winding is created via 2 magnetic couplings (wye-> delta and then back again). It adds some distortion to the 3rd leg, and uneven voltages too. Also, always risky to connect the POCO neutral to the X0 of a wye transformer. If things are not perfectly balanced (and they never are), objectionable currents can be created as these 2 mid-points fight to establish ground "zero". As pointed out above, you need to use the Neutral connection - otherwise L1 and L2 is just a single phase sine wave. But I would be unhappy about connecting up the neutral to XO forever.
If the PopeMobile was sinking in a lake (with the Pope inside) and all I had to power up the only available 3 phase drainage pump was this setup, I would absolutely save the Pope with it. But I would not use it otherwise, especially for sensitive customer equipment I might be liable for.
