electricaljohn
I understand that 3 phase medium voltage transformers can have an integral fused disconnect switch. This is not a typical installation; typically, they have pull-out bayonet type fuse holders on the primary side and not a disconnect switch. Does anyone have expeirence designing medium voltage transformers with integral disconnects, prefferably an oil-filled transformer section and air-filled 200A fused disconnect section? (15KV primary, 480/277V secondary, 300-750KVA, 150?-220? temp. rise) If so, what is a typical design, oil-filled switch and transformer section, air-filled, combonation, or whatever floats your boat?
Thanks
John
Thanks
John
