Strombea
- Prescott, Arizona, USA
I'm confused about hooking up a single phase 240v appliance (washer or dryer) to a 3 phase panel. A single phase system is 180 degrees phase offset and 3 phase is 120 degrees. So when hooking up a single phase 240v double pole (120 and 120) appliance to a 3 phase panel the phase shift is not that of single phase. Does the phase offset matter and will it affect the single phase motor?
It would seem that out of 60 hz at 120 offset but only using 2 phases, it would be missing power for 1/3 of the 60 hz?
