I have searched and can not find the answer, so here goes.
I have 16, 20amp, 250,volt receptacles, and two 30 amp, 250 volt receptacles to wire into a subpanel. the 20 amp receptacles have a load of 16 amps each. I can not find the formula to figure the size wire and ocpd needed.
This panel will be feed from a main panel that comes from a 45kva transformer.
If someone could post the formula so I can figure this out, I would be greatful.
