I have had a survey done on a set of 3 single phase transformers which make up a 3 phase, 300KVA, 7200 primary, 120/240volt secondary.
My issue is that per my previous research, 3 phase systems are either 480/277volts (line to line, line to nuetral, 208/120 volts.
It is my understanding that single phase systems can be 240/120volts )line to line, line to nuetral), 480/240, 480/277, or 208 (if both legs are connected together)/240.
Can my three phase transformer using a combination of three single phase transformers actually have a secondary made up of 120line-nuetral/240 line-line volts for each of the three phases??
