Hello All,
I have a 3 phase questions about a system that I was recently working on. I mostly work on the control side of things so my 3 phase Theory is a bit rusty.
A few years ago, this panel was purchased from an OEM. The input power was 600 VAC 3 phase, no neutral. This made sense to me because the load was balanced evenly across all 3 phases. The input power was supplying power to 3 x Transformers and each transformer was getting 600VAC.
After commissioning the manager decided that the system was too large and wanted to reduce power consumption. The OEM ended up retrofitting the cabinet. In this process the load being supplied by one of the transformer were all removed, so one transformer was removed from the enclosure.
If the we remove the 3rd transformer, shouldn't a neutral be brought into the panel to deal with the unbalanced load across the phases. If my calculations are correct. Phase 1 is being used for both transformer but Phase 2 and 3 are only being used for 1 transformer. Therefore a larger amount of current will be going through Phase 1 vs Phase2/3.
The reason why I'm asking is because we've been having issues with the enclosure ever since that work was completed. I couldn't find any issues on the control side of things. So I'm not looking into the distribution side see if something got missed.
Any help would be greatly appreciated. I might be missing something obvious, but as said earlier, my 3 phase knowledge needs a bit of refresher.
