hurk27
- Portage, Indiana NEC: 2008
I have this preference to the way these switches end up. Now this is my own belief but when I leave a house I want to see when all the switches in a circuit are down the light or outlet is off. The thing I'm getting at is we have a code for single and double pole switches and they even indicate whether or not there on or off but with 3-ways and 4-ways there is no indications unless we install them so that when all the switches are down the light/outlet will have no power on it. what started this is we had a home owner that was changing a bulb and when he was putting the new bulb in he stuck his finger in the socket, and he thought that it was code for it to be like this but I showed him that it wasn't he couldn't believe it. and this wasn't the first time this had happened as I found out that there is quit a few that believe that if all the switches are down there should be no power on the fixture.
Of course I told him that is why he should turn off the breaker, but we need to be realistic as we all know that that just don't happen. home owners will even change fixtures with the breakers on much less turn it off for changing a bulb. to me it would seem that since it is code to have a single or double pole to be down when it is in the off position would it be a good code to do this with 3-way's and 4-way's? (when all switches are down power off to the light/outlet)
Just thought I'd get someone's else's opinion
