hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
Original post:
Now you say:
What have you got?? I understand feed in>dimmer>light fixture>3-way switch. What cable do you have running from the dimmer to the light?? IS IT A 12/3?? because you make it sound like is is only a 2 wire!!
-Hal
*at the location of the dimmer*, I have the power coming in, the switch leg up
To the light, and a 12/3 wire running to the toggle switch...
Now you say:
Clearly as possible?? Now you change your story too! Now the light fixture is missing!I explained my scenario as clearly as possible.. I’m not sure how it is confusing to understand... at the dimmer switch there is as follows: FEED-IN, SWITCH LEG, and 12/3 to 3-way toggle switch..... I can operate the lights from the dimmer, and I can shut off the lights from the toggle. When that happens, I can no longer switch the lights ON from the dimmer switch.
-Hal
