Hello.
New home.
2nd floor bed room. Open attic above (Insulated).
Owner wants a 3 way between door entry and bed to operate light on fan/light.
Single pole to fan.
because of the shared neutral to the fan/light I'm thinking I need a four wire between the three ways for the same neutral being shared to the light /fan (and to have a neutral at the door 3 way switch)
THAT IS UNLESS I am able to use the exception of being in the same room and the switches are visible to each other.
You can stand at the 3 gang box and see the entry switch, but from the entry switch you can't see the bed switch (the 2' jog from the chimney obstructs view)
(1 ) Does this put the KABASH on that exception?
(2) If so, does the open attic allow me the other exception of future neutral to the entry switch ??
( even though I don't see how that would work well in the future as there would be a separate neutral from a different cable assembly)
(3) IF there was no open access above, would that 2' jog from the chimney which hinders the view of the switch be enough to have to carry a neutral to that entry switch?
thank you
New home.
Single pole to fan.
thank you
