brantmacga
Señor Member
- Georgia
- Former Child
Chris6245 said:Simple solution ....Just put a 2 pole switch in each bathroom. one pole controls the light like a single pole switch. The other pole goes to the exhaust fan from each. This does 2 things, it gives independant control of the light and fan from either bathroom. On the fan switch leg they tie together that way if one switch is on and the other is off it will still power the fan and nothing will change if the other switch is turned on. Now if the first switch is turned off still nothing will change until the second (or third or fourth) switch is off. As long as all the switches use the same circuit this works great.
I really like that idea, but you'd have to leave the light on to have the fan on. Whenever I climb off my throne though, I have to leave the fan running for awhile :grin: but don't want to leave the light on. I'll keep that thought in mind though for possible applications.
