3 way switches
Re: 3 way switches
the field weakens directly with distance.
The Biot-Savart law was so named in honor of the two French physicists who found experimentally that same relationship, just as you did. The mathematical representation came later.
Your observation around transformers, falling on the inverse of the cube, confuses me. Does your data show this to be true and uniform around a sphere that centers on the transformer? I would think a transformer would exhibit north and south poles (at any instant in time) and that the inverse cube would be most evident along the polar axis.
Re: 3 way switches
In response to al's prior post,Yes, the distance between any 2 switches was no more than 15'.
Re: 3 way switches
Al, and Karl, Good evening.
It's gonna take me some time to review your posts.
Al, I have to look closer but I think you're trying to cram a square peg in a round hole. On the other hand some of the empiracle stuff Karl's getting suggests I might have to look at it from a different direction to see what you're getting at.
Karl, Some of what you're saying about plotting different curves where it sounds like they shouldn't be so different is pretty interesting.
I don't actually know how well tested all this math hokus pokus is. It's just been handed down by the physics high preists.
Anyway, I have no more energy for this left today, so, first thing tommorow.
[ November 06, 2004, 11:12 PM: Message edited by: physis ]
Re: 3 way switches
Ok Al, let's do it.
Actually I'm going to bend a little here.
I don't think it can be expressed as a "point value".
Mathematically it can. It's analogous to the current we're talking about that is inducing the field. The current, theoretically, is in a conductor with no height or depth, yet is infinitely long and straight. Physically this makes no sense. . .super conductor technology not withstanding. . .and what about the curvature of space?
The differnece is that the current isn't a field. It's a collection of point charges. The individual values can be known discretely. A field has no independant discrete values. But, this is one of the two points I'll bend on. If you move far enough away it begins to appear as if the values are combined at a point. But we still know they're not. The reason we're allowed to pretend the current occupies a near infinatesimal space is because it doesn't effect the measurement of the field outside the conductor and that sure makes it easier. The reality is that you may have to apply skin effect and you know what that means. Think of the gravity of a hollow sphere.
Curvature of space? (space-time). Callin in the big guns, let's see if we can keep Einstien and Maxwell out of this.
Vector calculus allows the calculation of B at any point on the circular path of the flux. The vector that is tangent to the circular path points in the direction of the flux, and the magnitude of the vector corresponds to the flux density at that point. The Biot-Savart law is a vector formula.
Here's why I don't think that works. What I think you end up with is a vector sum at a point (used loosely) where there exists a real flux density value. If they don't match (and I haven't checked whether they do) then out with the vector in with the real. But, this is the other point I'm going to bend on.
B=L/A
I'll restate this because there's so many pages.
B = magnetic field (flux density)
L = lines of force (quantity)
A = unit area
This formula demands the lines of force be perpendicular to the plane of the area. We know that the flux lines around the wire are circular. So go figure.
Since you already know how and I'm cutting labor costs on this project I'm interested in seeing Biot-Savart in vector form.
Here, think of it this way, as we change the radial distance from the conductor to where we are calculating the flux density, we find the flux density changes (let I and ? sub r remain constant). If I try to look at a unit crossection area of the flux, all the points that are at different r need to calculated and added together.
This is how I confirmed what Karl Riley said about inversely proportional. Exept I'm using the formula I posted and u sub o. But those lines that are added together still exist in an area, not a point.
If I write a differential equation representing the change of B with respect to the change of r and then integrate it for a specific point, I can then get a result that represents the flux at a point r away from I as if the flux were uniform across an area.
This is where I think you're cramming a square peg. You can arithmeticly change it but you're no longer representing reality. Sometimes that's done for simplification when it doesn't effect the outcome. I think here you're getting the same outcome but complicating it.
Heh! Another idea is to think of the flux in Teslas, not in Webers/ft?
I was gonna tell you that the other day but the math I have has the Teslas disected. :)
[ November 07, 2004, 03:18 PM: Message edited by: physis ]
Re: 3 way switches
OOOOOOHHHHHHHH, I see what you're saying Al, r refers to a point, not an area. :cool:
Re: 3 way switches
Three way switches indeed!
[ November 08, 2004, 01:00 AM: Message edited by: physis ]
Re: 3 way switches
Indeed! Great discussion.
Al, I have measured pad mounted utility Tfrmrs by walking away from them to get the cube of distance (after the first couple of yards in square of). I didn't know which way the coils were wound. The field shape should be a doughnut I believe. You might have to be in a pretty tight area directly above or below the axis to get out of the cube relationship, but that would be good to try with a gaussmeter.
One interesting thing: small appliance plug-in Tfrmers can have much of their field canceled by plugging in another beside it. One way it adds, the other way it cancels. (Just in case there is one by your head when you sleep).
Karl
Re: 3 way switches
Karl, I'd be very interested in seeing how what you're measureing jives with all the whiz bang math and physics. The first time I did any of the math in this area was when I went after trying to find the relationship between field strength and distance. I'll bet this stuff isn't really any more out of your reach than it was out of mine a few days ago. :) All I have here is an old physics book I can barely understand.
From what you're saying it sounds like the field strength/distance might be nonlinear. I don't know what our current understanding is but I think we expect it to be linear. This could be another book!?.
Re: 3 way switches
Al,
Math is a language that's very hard to be fluent in. I hope I haven't offended you by being too inflexible in our arguments.
I respect the way you stood fast behind your perspective and also bothered to be informed about your opinions. :cool:
Re: 3 way switches
Sam,
It was a pleasure going over this. It's been entirely too long since I sat in that Vector Fields classroom.
The Prof. we had was legendary. He wrote on the blackboard inhumanly fast. Most days he would fill up the blackboards starting from the leftmost and, going across the room, six panels as I recall, start over again, erasing a panel at a time to provide new space. And then he, like as not, would do it a third time!. By the middle of the third pass over the blackboards he was lapping even the faster note takers in the class. To my great ire, I would lose parts of each of the last two or three blackboard panels, no matter how hard I tried to keep up.
Fields are a complex notion, IMO, and it has been great revisiting the basics in this conversation. :)
Re: 3 way switches
Hell Al, let's do the gravity of a hollow sphere and invite Bryan!
And I'm not moching you Bryan, I also have respect for you! :) you might not remember but I learned about tacions from you.
Re: 3 way switches
OH by the way,did I tell you all about the service call I went on that had (2) 3 way switches and a 4way and the white wires were cut off at the 4 way?,,,,,is this common practice?.(just kidding) I was just trying to push this baby over 100 replies.
Re: 3 way switches
to help push it over the 100 replies, AND now that we seem to be over the vector analysis, the best reason for always running three wires is that that the lights and the feed can be placed anywhere along a 4-way string.
paul
Re: 3 way switches
OK,been busy but when i saw 7 pages I read through and through all this,nobody has mentioned that the same type of switching is done day to day with 3 wire cable assys.Switch and feed from a 4 ways location since the light
/fan/receptacle is closer to this switch then 1/2 way across the home.I my self have wired many lanai:es/porches with 2 2 wires from a 3 way to several 4 ways where there would be a single pole switch either for a ceiling fan,flood etc. needed a neutral and a hot to there.continue in 3 wire to complete the loop.Is this any differet from a 2 wire traveller.lets take a 2 gang box,3 way switched fan/lt. light switched fan constant hot.Same box 3 way swiched receptacle.3 wire to the recep. and fan/lt. 3 wire to each corrosponding 3 way.Done 4 pieces of 3 wire.Dead ended switches are all over in commercial,residential so why all the fuss,dont want the computer moniter in a home to flicker get a dedicated circuit.Residential is so cost affected that even 15 min of manpower is saved to complete a common task multiply that by 1-2-3,000 homes a year well get the pic.Personally I have this same switching in my home.I feel comfortable about it. ;)
Re: 3 way switches
Forgot to add I would never use 2 wire travellers and grab a neutral from another circuit.To much chance of loosing the neutral and having the shared circuits on different phases :(
Re: 3 way switches
Allen.
dedicated circuit.
how will this help if there are PQ issues from another source?
Roger
[ November 11, 2004, 06:59 PM: Message edited by: roger ]
