Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
You mean circuits need to be in close proximity for low impedance for EGC and EMT for ground fault return path230608-1434 EDT
I do not understand what most of you have been saying.
Don't use the words hot, neutral, and .EGC.
A 3-way circuit consists of a power source, a wire from the power source to a first switch, next two wires to a second switch, a single wire to the load, and a return wire to the power source.
The important point is that this circuit needs the return path for any conductor to have in close proximity a conductor that carries the same current in return to provide a counteracting magnetic field to the forward current's field.
