. . . his 3-way switching circuits numbers 9 and 10 are non-compliant with the 2011 NEC . . .
More than the 2011 NEC is in play. As an example, take a closer look at #4, the so-called Chicago Threeway. The polarity of the lampholder changes, depending upon switch position. That has not been "compliant" with the NEC since back in the Twenties.
But, if you've ever worked on a wiring installation from before the required polarity of the lampholder went into effect, knowing that such a thing could exist will greatly de-mystify the initial troubleshooting. You will also be able to serve your customer better for the knowledge.
I live in an area that has a good number of single family two story dwellings built before 1920. Most of these were originally wired with Knob and Tube, and have a light over the main stairwell that is controlled by a pair of threeway switches. That threeway stands an excellent chance of, not only, being a Chicago threeway, but also a Chicago threeway installed between the upstairs circuit and the downstairs circuit. Now. . . imagine doing a simple panel changeout / service upgrade, and, without anticipating this, you put those two original K&T circuits on opposite buses. . . .
Ronald's animated switching diagrams communicate, in a short space of time, what static diagrams would have you wade through in pages of print to understand. And they are a treasure trove of the kind of installations one will find out in the "wild" including the Tennessee threeway.
