The power company is changing the service at an older house from overhead to underground. The old service is a 3 wire meter feeding a 3 wire panel inside the house. The old panel had the main bonding jumper between the water pipe grounding electrode and the grounded conductor. The new service has a meter and overcurrent with a new Water pipe Grounding electrode conductor and main bonding jumper so the old panel's feed is now classified as a feeder. I can find how to add a new receptacle in a 2 wire system but not how to ground an existing panel in this situation. I do not believe this is an uncommon problem. I assume the grounded conductor (neutral) would bond the panel enclosure even though this is not allowed in new installs. Any thoughts. .
