Paul Allen
Electrical Contractor
 - Middleburg Florida
 - Electrical Contractor
So in a situation where there is a three conductor range and dryer circuit on the premises, and was fed off of a main breaker loadcenter.
New generator is installed with Service rated transfer switch, and four conductor wiring is installed from new switch to existing loadcenter.
Grounds and neutrals are separated, panel is now a feeder panel by definition. Circuit neutrals are terminated on the neutral buss, not grounding buss.
Problem, House is two story and three wire circuits cannot be accessed for replacement. Any code compliant way to be able to install this, or does the generator install or a potential service change get cancelled because owner doesn't want to tear out walls and ceilings to rewire.
What are everyone's thoughts on this? Would a code modification to allow 240 volt GFCI protection be a safe way to allow three wire circuits to be used when rewiring is not an option? let me know what you think.
