3 wire sub panel for 220
joshd23
New member
Colorado
Hello All,
Here's my scenario:
I have a 3 wire 240 volt 50 amp at the main that was used previously for an oven. I want to re purpose this to a sub panel to have a few 15 amp 240 lines. The sub panel will be in the basement, so no conduit between the main and the sub panel.
The question is related to neutral and grounding. Should the neutral and ground be bonded in the sub panel, or should they be separate?
If separate, when wiring the 220 volt outlet should the ground on the outlet be to the ground in the panel or the neutral.
Thanks.
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
