3 wire to 4 wire conversion for Hot Tub
My3sons!
New member
Redmond, Wa
I'm installing a new hot tub, replacing and existing one that was wired with only 3 wire (two hot/one ground). When determining if I was going to replace the entire line, I realized the main panel is still single ground/neutral bar (grounds and neutrals are all wired to the same bar). Since the main panel is shared ground/neutral, is it still required to run a dedicated ground all the way to the panel, or can I marry the ground to the neutral at the tub? (also, read conflicting opinions on grounding rod, any thoughts there assuming I use the 3rd wire going to the panel as the neutral?)
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
