- Massachusetts
So Bob, by your interpretation you cannot run EMT on the underside of the metal pan unless it were mounted on 1.5" or larger strut?
Yes that is exactly my view. :smile:
Is the section aimed at protecting raceways and cables from screws?
Do screws typically come through the lowest rib of the metal pan?
My thought is that it's to prevent it from being run between the top of the bar joist and the metal pan unless you can maintain a 1.5" space.
I wish that was so but I do not believe it to be.
