1.21 Gigawatts
- Norwalk, CT
- Journeyman Electrician
Anyone look at the Reliance 310A and 510A Transfer Switches side by side? They are the same except for one thing. The 310A supports up to 7500 watts. The 510A supports up to 12,500 watts.
Breaker sizes are the same. Max breaker sizes are the same.. Wires are all the same sizes including temp rating except for the Neutral. On the 50A 510A it's a 8 gauge. On the 30A 310A its a 10 gauge.
I spoke to tech support there and he acknowledged yes, its the same except the neutral wire. He said you can basically put a larger size wire in the 30A TS and call it a 50A TS but it would pose problems if something happened and they see the model number, ect.
Just thought I point that out. Essentially $100 bucks more for a larger neutral wire only 2 feet long. Unless you guys know something else.
50A on left. 30A on right.
