Been asked to take over a project that was started about 6 mos. ago previous co. partially wired a house, home runs went to 3 locations.
There is a 400 amp ch panel about 270 ft. away from house on a framed back board. There is a 3 inch and two 1 1/2 conduits to house with pull box in between. Can I use 310.15 b6 to size one run in 3 inch 4/0 al to 200 amp and 1 runs in ea. 1 1/2 conduit to both 100 amp panels in home. Where the 1 1/2 conduits enter the dwelling(garage) can I bring them into a single pull box and continue with two seperate ser cables. also would I bond the ufer which is at the 200 amp in series to the 100 amp panels ? any corrections or better ideas appreciated. TIA
