310.16 correction factors
Re: 310.16 correction factors
Originally posted by stew:
I am also trying to see whether the lugs might be rated for 90 deg and then use a 225 amp breaker rated 90 degrees and the problem would be eaqsily solved.
I believe there is a code section that states you can never use the 90 deg except for derating for voltage drop and temp and stuff.
actually you can use the 90 deg table as long as you use a compatible device.But I have since found that the feed thru lugs are only rated 75 deg so I am back to square one.Cant find a 90 deg lug.
[ May 05, 2004, 02:59 PM: Message edited by: stew ]
