Bob NH
- The "Live Free or Die" State
You might be able to find a 2" raceway or duct that would fit in the recess with a cover that can be removed for access. Make it as long as you need.cdwirenut said:Originally I would have had only 6 # 12-2 with ground but I found another 240V line in my wall I wanted to run into the thermostat box for possible future use. I really didn't want to go wqith a 4x4 box because I'm trying to keep my post(location of this box) as skinny as possible.
Is there a long skinny box out there that could give me the cu inches I need?
Since you are going to have heaters along the baseboard somewher, maybe a finished box mounted at the floor/wall corner would not look to out-of-place.
I have also seen corner raceways that could mount in the floor/wall corner that would not look bad next to a heater unit.
An external box of some kind on the face of an outlet box would not look much bigger than a big wall-wart power supply.
The ones below may not work but could give you some ideas.
http://cableorganizer.com/wiremold/wiremold-aluminum-surface-raceways.htm
http://cableorganizer.com/cable-raceway/#Wiretrack
http://cableorganizer.com/surface-raceways/
