352.46 poll
352.46 poll
  • Yes. On any size PVC with any conductor
    Votes: 6 16.7%
  • Only on runs containg #4 or larger conductor
    Votes: 20 55.6%
  • Do not require on any
    Votes: 9 25.0%
  • Other
    Votes: 1 2.8%
  • Total voters
    36
  • Poll closed .
Yes, that's what I'm saying. If you look at the edge of the TA it's far from smoothly rounded. Screw on a plastic bushing and then it becomes:
Ok, fair enough.:)
Like Bob has said this is a judgement call by the AHJ and the only opinion that matters in theirs.
Chris
I had a new underground service installed this week.
I left a piece of 2 1/2" sch 80 PVC pipe with a male adapter, lock nut and bushing installed on the end of the pipe.
I also cut the pipe so that it would have 24" depth after installation (only 18" is required).
The POCO came to install the DB cable in the (my) trench the next day, when I wasn't on the job site.
Next time there, I looked in the meter base and sure enough, the bushing was laying in the bottom of the can. The POCO didn't use it.
I realize that they don't have to comply with the NEC, so I wasn't suprised, although I do try to cover all the bases.
So I left a bushing in case someone thought one was needed.
That said, I don't normally use a bushing on PVC Male adapters, but I do use a pocket knife to remove the sharp edge from the inside lip.
I've seen PVC adapters damage the outer sheath on cable when pulling, especially on smaller sizes, so I remove the sharp edge.
Code or not, it's (IMO) a good idea and practice.
steve
FYI,
the reason I started this thread was because our local inspector is at a loss. He is the AHJ and he's unsure about what call to make.
