steveve1
- Tucson, AZ
Hi Guys, It's been a while. We have installed 4/0 Al SER cable to provide 200 amp service to interior mounted panels. As the connection lugs of the connected equipment are rated at 75 deg C, the ampacity rating of the conductors is reduced to 180 amps per the 75 deg column, but 240.4 allows OCP to be 200 amp as the next standard rating. As 2' of the conductors terminate in an exterior cabinet exposed to our Arizona temps, the engineer has called for an ambient correction factor of .82, thus allowing an ampacity of the installed cable at 148 amps. What say you? Thanks always.
