emiller233
- pittsburgh, pa
- Controls-Automation engineer
we have a customer that has a DCS that is monitoring a flow sensor over a 4-20mA signal. we do not have any info on their DCS.
They would like to add a local display(for the flow) out near the sensor. and the displays that would be used is a Omron# K3HB-XAD 24VAC/VDC with a option card inside of it that can transmit a 4-20mA as well (Omron# K33-L1A)
https://www.ia.omron.com/products/family/1535/specification.html
The flow sensor is a FLOTECH F6206-AIV-DS
https://www.google.com/url?sa=t&rct...r-Manual.pdf&usg=AOvVaw0n8qYNOYO8_A9v6tZDN6ae
my question is, can i just add the Omron display in series between the flow sensor and the DCS, using the current + and - on the display?
or do i need to use the retransmit capabilities?
I've tried attaching the manuals, but it keeps saying there are errors. the links above should get to the data sheets for these (if they're not attached)
