4" Core through floors
Drilling may seem more time consuming but overall its a better lookin job, and as said easier and less costly to fire caulk. Just make sure there is no radiant floor heat...as an apprentice I did some work at an old prison in PA the journeyman said drill here and left it was like the first time I ever did any core drilling. well things were going good, taking my time kept the vac going to catch the water so as not to make a huge mess. Well, guess you can visuallize the rest. They had metallic pipe for the radiant floors.
Great question
Exactly why though? Thanks.
Because you have to be able to look in a fire stop manufactures book and find the exact application that you are doing. That's why. So if you have a big hole and they don't have it in their book with your conduits in it then you have to pay them to engineer a firestop solution for you.
Now these holes might be in a area that is fire stopped off from the rest of the building like a utility chase up the inside. I've seen those not having to be fire stopped.
