If you first heard the word, "Coefficient", would you think a percent of something, but would you really think of the following?
Coefficient of Friction
Factors affecting the friction between surfaces
Dry surfaces
For low surface pressures the friction is directly proportional to the pressure between the surfaces. As the pressure rises the friction factor rises slightly. At very high pressure the friction factor then quickly increases to seizing
For low surface pressures the coefficient of friction is independent of surface area.
At low velocities the friction is independent of the relative surface velocity. At higher velocities the coefficent of friction decreases.
Well lubricated surfaces
The friction resistance is almost independent of the specific pressure between the surfaces.
At low pressures the friction varies directly as the relative surface speed
At high pressures the friction is high at low velocities falling as the velocity increases to a minimum at about 0,6m/s. The friction then rises in proportion the velocity 2.
The friction is not so dependent of the surface materials
The friction is related to the temperature which affects the viscosity of the lubricant.
Based on this here.
