- Tennessee NEC:2017
- Semi-Retired Electrician
Is it permissible to mount 4 sq boxes using the holes in the side to run a screw through?
I have an install to do in a shed/barn (no animals or agriculture) that the support posts and slating for the outside metal is going to be left exposed. IOW, it will be open inside.
I use the boxes with the brackets sometimes and they are fine for lights or junction boxes.
However I don't like to use them for receptacles. They seem to flex/give too much when plugging/unplugging things.
