Along with Sii's illustration the link below is an interactive 4 way switch from forum member Ronald Coleman.
http://home.comcast.net/~ronaldrc/wsb/c4.htm
Roger
Roger
I don't see why 4 ways need any marking. You put one set of travelers on one end of the switch and the other set on the other end of the switch. In one switch position the path is straight through from one end to the other end and in the other switch position the path is in a "X" from end to end.
Back a few years ago there was one brand that did wire from side to side, travelers went to one side and out the other side, it was frustrating to get the guys to watch out for these, the bad thing was they didn't mark the screws like most do.:rant:
I guess I have not run across that layout. About 20 years ago there was a single pole switch that had the screws on the left side and not the right side....the first dozen or so of those that I installed were installed upside down as I did not even look at them...just took them out of the box and held them with the screws to the right and put the hot on the top screw and the switch leg on the bottom screw and installed the switch. One of my guys asked me at break why I was putting the switches in upside down.Back a few years ago there was one brand that did wire from side to side, travelers went to one side and out the other side, it was frustrating to get the guys to watch out for these, the bad thing was they didn't mark the screws like most do.:rant:
Please tell me that (if?) I have this right. You want to control all the lights in a small room with a total of three manual switches (i.e., near the three exit doors). Here is the control scheme:
Regardless of the existing position of the three switches, if the lights are off, then changing the position of any switch will turn them on. Also, regardless of the existing position of the three switches, if the lights are on, then changing the position of any switch will turn them off. [/list
I believe that to accomplish this, you need a pair of 3-way switches and a single 4-way switch. I am being told that all three switches have to be 4-ways. Am I right?
	Bit of a surprising question from a PE I thought. But well, maybe not when I think of some in the profession. I suppose I'm a fairly pragmatic and practical sort of fellow. As a professional, I know stuff. As a practical person, I can do stuff.
Anyway, this what you need:
SW2 is what we (UK) would call an intermediate switch. You can string as many as you wish in the circuit.
No doubt you have different symbols but I'm sure you get the idea.
Not at all. Wiring diagrams are not on the PE test, and the subject is not taught in the university. But I did believe I had it right. That said, one must take extra cautions, before telling a client that they are wrong.Bit of a surprising question from a PE I thought.
I agree. Badly drawn.A
Your switch arrangement will not work as drawn turn either 3-way on and the light will still be off.
In your 4-way, or intermediate switch, I believe you need another line from top left to bottom right. When you throw the switch, the two lines would be shown as one across the top from left to right, and the other across the bottom from left to right.
yeah, prints are rareThey actually gave you blueprints?:lol: I've had to design every one that I've ever wired! I had one owner that wanted to be able to control the floodlights from every room in the house, ended up with two three ways and six fourways! The kicker was when he bought the floodlights, he got the ones with motion sensors!:roll:
me too, now I check 1st with continuity when I put in 1st 4/way, even though they've all been the same for a long time, then don't check any more until next timeI have seen a few 4 ways that were not clearly marked & had to do a little trial & error. That's 1 of the most common punch list items I used to see. Switches worked OK most of the time, until a particular 4 way was in wrong position. I used to take the 4 way out a moment & verify correct connections on the 3 ways. Then put the 4 way back in & check all positions, change terminations as needed.
