I just installed a light controlled from 3 switches, normal configuration, a 3-way at each end and a 4-way in the center.
Of the 8 possible up/down combinations of the 3 switches, ie, up/up/up, up/dn/dn, etc, all but one combination works properly. The one switch combination that fails has the light off when it should be on.
Rather than troubleshooting with a voltmeter, I decided to use pencil and paper to try to determine what type of fault could make the light operate this way.
Now there are a lot of ways to mis-wire this circuit, in addition to the possibility of a faulty switch, but by my calculation, there is *only* 1 possible problem that can produce these symptoms.
So what do you guys say?
-jim-
-jim-
