Brad Baxter
Ideas and inputs on a 400 amp service.
I am installing one of those GE 400 amp meter combo's with 2- 200 amp breakers in it. It's actually called a 320a continuos type combo. It was high at $1700. I am still shopping for something cheaper. Someone told me they found one for $500 and i find that hard to believe.
I am going to connect the line side with 600 aluminum and leave load side breakers with 2- 4/0 ser al for my 2- 200amp panels in the basement. My question is has anyone did this a better and less expensive way and how much did you pay for the combo?
Also did you use a #6 copper for your 2 ground rods continuos to the meter like we normally use for 200 amp services or did you run a 1/0 copper to both ground rods?
Thanks.
Thanks.
