Scenario: 400 amp rated meter enclosure with no disconnect. Ground rod GEC bonded to neutral in meter can. Meter feeds two 200 amp panels in house, each panel has a 200 amp disco. Water service GEC is ran to only one of the panels where it lands on the grounding bus. Dosent the other panel also need to be grounded to the water service? Hope this is enough information.
