cwborg
New member
- beggs, Oklahoma Okmulgee county
Im hooking up a 400 amp service to a 6000 sq foot building and having trouble finding a source for the disconnect shown in the attached pdf. Power company requires a box with a 400 amp breaker with a maximum of 8 additional slots. Is it allowable to use a box with just a 400 amp breaker and make multiple connections with 4/0 4/0 2/0 to connect to different 200 amp panels in the building? If so are you limited to only 2 200 amp load centers or can you install 3 or 4 since the service has the 400 amp breaker? I called the engineer at the power company and he told me they didnt care what we did after the 400 amp breaker. This county basically has no local code regulations, no permits required, no inspections, nothing.
