Stevenfyeager
- United States, Indiana
- electrical contractor
Since a two gang meter base ( 2 - 200 amp) is not available from supply stores here, the customer and POCO and inspector are ok with me installing a trough, with 2 - 200 amp disconnect combos on each side. POCO says they will come underground with 350 Al, and I plan to use 3 barrel insulated lugs inside the trough. How big of trough should I use ? Thank you !
