james wuebker
- Iowa
Putting in a 400 amp service single phase 240v. Got a 320a meter socket will install on building. On the inside wall, 2' away from the meter will be a 200 amp panel with a main in it. OK just below the meter on the outside of the building I'm going to install a 200 amp disconnect for the house about 150' away which will have a 200 amp panel in it with a main breaker. Does the tap rules apply and is this OK do it this way. Also where would be the first disconnect if bonding the neutral and the grounding wire of the system?Ideas or should I start with a new game plan.
Thanks!
Jim
Thanks!
Jim
