400 Hz electrical systems
ruxton.stanislaw Spammer
Suspended Member
Arkansas
Laboratory Engineer
400 Hz electrical systems are a type of alternating current (AC) power system that operates at a frequency of 400 cycles per second (hertz), which is significantly higher than the standard 50 Hz or 60 Hz used in most power grids around the world. Here's a breakdown of their key characteristics, applications, and some pros and cons:
Applications:
  • Aerospace: 400 Hz is the standard frequency for electrical power in aircraft. Aircraft generators are driven by the jet engines, and a 400 Hz system offers several advantages in this environment:
    • Weight and Size Reduction: Higher frequency allows for the use of smaller and lighter transformers and motors for the same power output compared to a 50/60 Hz system. This is crucial for weight-sensitive aircraft.
    • Compatibility with High-Speed Rotating Equipment: Many aircraft components, like generators and actuators, operate at high speeds. A higher frequency AC system aligns better with these high-speed components.
  • Military Applications: 400 Hz systems are also used in some military vehicles and ships due to the weight and size benefits.
  • Ground Support Equipment: Airports may utilize 400 Hz power for ground equipment that services airplanes, providing power for tasks like starting engines or operating onboard systems while the aircraft is grounded.
How it Works:
  • In an aircraft, 400 Hz AC power is generated by alternators driven by the jet engines.
  • This AC power then supplies various electrical systems on the aircraft, including:
    • Avionics (navigation and communication equipment)
    • Lighting systems
    • Environmental control systems (air conditioning and pressurisation)
    • Landing gear actuation systems
Advantages:
  • Weight and Size Reduction: As mentioned earlier, a major advantage of 400 Hz systems is the ability to use smaller and lighter transformers and motors for the same power output compared to lower frequency systems. This is crucial in applications like aircraft where weight is a critical factor.
  • Reduced Skin Effect: Skin effect is a phenomenon where AC current tends to concentrate on the outer surface of a conductor at higher frequencies. While this can cause some inefficiencies, in the context of aircraft wiring with smaller cross-sectional areas, it can be less problematic compared to a lower frequency system.
  • Compatibility with High-Speed Equipment: As stated before, 400 Hz AC aligns better with the high-speed operation of many aircraft components.
Disadvantages:
  • Limited Availability on Ground: Since 50/60 Hz is the standard for most power grids, 400 Hz power might not be readily available on the ground. This can necessitate special equipment or converters for operations while grounded.
  • Increased Leakage Current: Higher frequencies can lead to slightly higher leakage currents in cables, which needs to be considered in the design and insulation of the system.
  • Potential for Interference: Higher frequency systems can potentially create more electromagnetic interference with other electronic equipment onboard the aircraft if not properly shielded.
Overall, 400 Hz AC systems offer significant advantages in terms of weight and size reduction, making them the standard for powering electrical equipment in aircraft. However, their limited availability on the ground and potential for increased leakage current and interference are some drawbacks to consider.
Motors, generators ( alternators) and transformers require less magnetic material resulting in less weight.
Generators ( alternators) can be run at higher speeds, with a resultant savings in reduction gearbox weight and complexity.
Actually, for 400 Hz, skin effect is negligible
At 400Hz, the skin depth comes to 3.2mm (for a solid 8AWG conductor, this includes the entire conductor); when looking at 3kHz, the skin depth drops to 1.19mm. As a quick back of the envelope estimation yields that the high frequency uses about 8% less of the conductor at the 3kHz than at 400Hz.
As the conductors get bigger less and less of the cross sectional area is used.
