jimmyjohn
New member
- Tulsa, Oklahoma
I have a commercial service where I am installing a 400amp service to.
I was told 600MCM is what I needed to pull, is that correct? If so what size wire should I use if doing it in parallel?
If I run it parallel, can I put the wire in the same conduit if it is just a 6'' conduit run from the meter can to the panelboard (stub)?
